:: How to open the inlet inside the crankcase?
Home Forums English General questions How to open the inlet inside the crankcase?
  • #144368
    Coolvette
      Hi all,
      I am new here, come from Sweden and I will modify a Super Bravo to be a good accelerator, I don´t care much for top speed.
      Can you please advice me on how to open the inlet port inside the crank case to allow more fuel to get in there?
      I am aware of that too much opening will spoil it so I better ask before I ruin it.
      I would like to see some pictures and mesaures over how much it can be opened here.
      Thanx in advance
      #146250
      ! Joor !
        this is what you’ll have to do, althou the how to is made for an dr evo 43mm cilinder.
        http://www.vespa-ciao.nl/page.php?id=187
        #146252
        woetie93
          Welcome to the Vespa-ciao forum.
          I think this one will help: click!
          #146247
          Coolvette
            Great guides, both of them!!!
            I´m glad the winter is ahead of me, I will make this in my own time.
            In fact, I do have an Dr Evo 43 mm cylinder so I find this very useful.
            A question about the modified crankshaft:
            I might buy a TopRacing crankshaft to put in my engine.
            Will the opening timings on that crank be like the modified stock crankshaft above?
            #146253
              dont do it you wil get something like this
              #146254
              keltow
                The TopRacing Crankshaft will brake in no time. A real waste of money.
                It’s best you modify an original piaggio crankshaft, these last forever.
                43mm cilinder = 4.3×((0.25×π)×4.3^(2)) = 62,45cc
                #146255
                Coolvette
                  ritze :
                  Shit!!!
                  I´m convinced to leave that alone…
                  By the way, how does the Ciao engine respond to a lighter flywheel?
                  My plan is to build a light machine for dragracing over a 75 meter race track.
                  The setup this far is a Dr Evo 43 mm cylinder, a Polini Top One exhaust, a Malossi variator.
                  The carb will be a 17 mm Bing, just for the easy finetuning and I plan to use E85 for fuel.
                  My plan is also to remove the lightcoil from the engine and also mill off the cooling fins on the flywheel.
                  As I only will race for a short distance I don´t think it will overheat without the cooling fins.
                  The E85 will combust at a lower temperature but I´m a bit concerned to find a good oil to mix in the E85.
                  So some questions:
                  How will the engine respond to a lighter flywheel?
                  Is the flywheel from a CDI engine equal to a pointer flywheel?
                  Have you ridden on E85? What oil do you recommend to mix?
                  Anything else I need to consider?
                  #146256
                    – Lighter flywheel; is quicker pickup of the engine and little bit faster acceleration.
                    – Electronic flywheel(+1kg) is much heavier then that of an pointer flywheel(somewhere between 700 and 1000 grams)
                    – No experiences with this kind of fuel.
                    #146257
                    Coolvette
                      Martino :
                      – Maybe this topic will interest you? Unfortunately all in dutch but this could be a perfect idea for you drag races.
                      Thanks for reply, too bad my knowledge in dutch is a bit too low for tht link.
                      How is the ignition point determined on a CDI flywheel?
                      Is it possible to use a pointer flywheel on a CDI engine, will it fit and work?
                      #146258
                        it is deremined with the pick up, but there is not much you can alter, i think that the timing is not so bad.
                        E85 fuel has a low octane count, witch not improves the performanse of youre engine, try racing fuel instead
                        like octane 100+
                        17mm carb is not going to fit a normal block, it only fits a speed engine, reedvalve, of evo engine.
                        flywheel can be lightend but removing the fins is causing a very hot cilinder witch doesn`t improve performanse
                        unless you make it h20 cooled like this:
                        #146259
                        Coolvette
                          ritze :
                          Does anyone know of the quality of Pinasco crankshafts?
                          Are they as fragile as the Top Racings shown in the picture?
                          #146289
                            the pinasco`s are much better in durability so breaking wil not be an issue 😀
                            #146290
                            Coolvette
                              ritze :
                              OK, great to hear.
                              I will take advantage of the drilled tap and also use the full round crank to fill the crankcase.
                              Thanks for your feedback.
                              #146305
                              Kamelen
                                E85 has a Octanevalue of 104 RON while “normal” fuel has 98 octane so yes , it should higher the performance of your engine
                                // Sebbe @ MNF
