:: How shall I install the Mazzucchelli crank?
Home Forums English General questions How shall I install the Mazzucchelli crank?
  • #144279
    Coolvette
      I have an semiround Mazzucchelli crank I will install in my engine but a closer look made me wonder one thing.
      Have a look at these pictures.
      It looks like the shim inside the bearing is already on the crank from the manufacturing.
      The withs of about 33 millimeters are similar to the stock crank withs so I believe that I must install the bearings with no added shim inside.
      The following instructions doesn´t tell this at all but I believe I am right.
      #146127
        you could try to pinpoint the measurements from the ´ring´ to ring and try that on a stock
        if its the exact same do not add rings
        different prehaps you have the ability to remove the rings and add normal shims.
        #146377
        Jarco
          I have the exact same crank on my setup, install it whitout the shim rings. :thumb
