:: How many km before full Throttle
I have mounted my new engine to day,new cylinder kit + new bearings, how many km before full throttle ca.:)?
500 km is pretty much but it is put in the manuall of the cylinders..
like 200-300 is enough, but make sure your “sproeier” is good
A normal cilinder about 300 km. Aluminium cilinders just 150 km. Remember after first time starting let it run without accelerating. Then let it cool down and start again after 15 minutes. For the first 50 km make sure your engine does not get really hot. After that you gently go a bit faster every time you drive. Also sometimes give it full throttle for 10 seconds so you don`t get a sediment layer in your cilinder! Be friendly for your cilinder and it will please you long time!
