:: How do I install a Malossi variator?
Home Forums English General questions How do I install a Malossi variator?
  • #144370
    Coolvette
      I have bought the Malossi 51-3863 variator, told that is a good one for a tuned bike.
      I don´t really understand how to install it, the enclosed instructions a bit vague to say the least.
      Can anyone help me with some pictures showing this.
      Wich rolls is the best to obtain the best acceleration?
      I don´t care for top speed, I just want it to be a fast starter.
      What is your impression about the Malossi variator, is it good or crap?
      #146260
        [url]/page.php?id=295[/url]
        What is your complete setup ?
        #146261
        Coolvette
          hansieb :
          Thanks for the input, I still don´t see where to put the large yellow spring thou.
          My recent setup are quite mild I think:
          Dr Evo 43 mm cylinder, the crankcase will be adjusted to meet the ports.
          The local race regulations are 70 cc aircooled and 50 cc liquid cooled so I won´t pass the 70 cc limit.
          Polini Top One exhaust pipe
          The carb will be a setup of my own, I will come back to that when I have decided my choice.
          Lightened flywheel to help the engine rev up faster.
          The moped will be run only in short dragraces so I plan to drive it without cooling fins on the flywheel.
          To ease up the revving the light coil will be removed too.
          Perhaps I also will run it on E85 but time will tell.
          I still need help to understand the Malossi variator installation, see the beginnig of my reply.
          #146262
          Spulleke!
            Hey, here you can see where the big yellow spring needs to go.
            http://vespa-ciao.nl/page.php?id=227
            It’s for the rear variator i recommend u to use it and also install 3 little yellow springs u can see how u install them;)
            Good Luck:thumb
            #146263
            Coolvette
              Spulleke! :
              Good Luck:thumb
              OK, I see, I didn´t realize it was meant for the clutch, I expected it to be with the variator…
              Thanks a lot.
              Note that I have an Super Bravo but the clutch looks just the same on the picture from JMPB.
              How does the tiny yellow springs affect the clutch?
