:: How can my ciao go with this setup?
Polini 75cc
13/13 Dellorto
Polini luftfilter
Polini Speedengine motorhus
Polini SP
Malossi MHR Multivar
Malossi Utväxling
Superbravo slungkoppling
Malossi special belt
_______________________
Any suggestions?
I think your speed would be around the 75 km an hour
Open your trohtle and Go !!
Where in Sweden do you life ?, i like to go there on vacation a lot.
Lurking for old cars.
Im sorry for writing the setup in swedish, i was tired and copied it straightaway from my project on a swedish moped forum.. (http://forum.moppenet.com/showthread.php?t=68437)
75km/h sounds okay..
Crullie: I live in Haninge, near Stockholm!
I suppose that “Malossi Utväxling” are the gears for in your rear wheel for the Variomatic.
If you use the normal gears in your rear wheel your topspeed will be limited to 70-75. However with the “fast” Malossi Gear set you might go 80-85 km/hour, but that is only posible if you fine-tune your ciao very well.
Yes, the “malossi utväxling” is malossi gear set..
Thanks for the help.
Then your ciao will go 90 if you tune it good..
Are you sure? that would be awesome in that case.. but do you mean to tune the cylinder? or just tune the carburetor and such other things well?
90 km/h is way to fast with an speedengine.
I think about 80 – 85 km/h maximal with malossi gear and variomatic
you guys think he would get 85km with a 13mm carb? that’s awesome. what if he were to go malossi with the engine and have a 19mm on there?
With variomatic you need a pretty strong setup to get to 85km/h
Pully it isnt a problem
