:: How big Jet
Home Forums English General questions How big Jet
4 berichten aan het bekijken - 16 tot 19 (van in totaal 19)
  • #145401
    TimoO_
      yes i think there are some people but if you wan’t your engine to go faster and if you don’t want to damage your cylinder, i think you should use another filter.
      #145403
      frandecool
        Thanks, i will try whith a power filter then.8)
        #145404
        G-no
          If I were you, I would buy a malossi reedvalve filter. The problem with the most powerfilters is that they let in too much air for this kind of carburator (on a vespa), so you will never get your engine running the way you want.
          #145405
          frandecool
            G-no :
            Okay i will try that.
