Home › Forums › Algemeen › Brommers algemeen › Het grote “vespa oldtimer” topic
- Dit onderwerp bevat 1,004 reacties, 121 deelnemers, en is laatst bijgewerkt op 6 jaren, 7 maanden geleden door AA-T.
28 januari 2017 om 20:16 #122565
Well i made a quick comparison, see the list below.
It could be the original number, but as usual it is quite hard to confirm.
The carburator looks very clean, somebody must have taken good care of it.
29 januari 2017 om 00:43 #122566@ Ralf,
The engine is original, and the frame number is from January 1969. Good luck finding all the correct 19″ parts for it. That will be a very thought job as none of the sheet metal parts from a 17″ will fit (if you want to keep it 19″Italian version ) .
29 januari 2017 om 10:13 #122567😀 missing 19″ metal parts as fenders, fork, bagage drager…. are on the way to me. Should arrive comming week.
Is there something special on Italian C9’s what makes them different to Dutch or German ones?
After what info is the frame from 1969?
After my list the number is more or less in the middle of numbers in 1968.
Regarding the engine, it has an L-piston. Is that something what was available at that early time?
Also found this “star” on the saddle support area. Is that specific?
Too bad, there is not much left of this sticker.
Jos, here are some more pics from the front sticker. I can’t read Italian, so no idea what missing letters could make sense.
29 januari 2017 om 22:24 #122571@Ralf, I have checked again, sorry but I made a mistake. It is from the 11 or 12 month of 1968. Some that I saw where later registered in 1-1969. The sticker on front is from a reseller. Could you make large pic from the front?
5 oktober 2017 om 19:46 #122867Ik heb een Ciao C7 met starre voorvork. Kan ik de rempot met remsegmenten uit het voorwiel van de C7 halen en die in een tien-spaaks 16-inch velg stoppen en die vervolgens monteren in mijn starre voorvork?
5 oktober 2017 om 20:20 #122868Nee dat gaat niet, de rempotten zijn niet uitwisselbaar tussen de verschillende modellen.
Waarom zou je dat uberhaupt willen, je hebt toch niet voor niks een starre gekocht 8)
5 oktober 2017 om 20:28 #122869De spaken van mijn wielen zijn echt af. de meeste zitten los en er is er nu ook eentje gebroken. Ik heb voor €20,- een setje tweedehands wielen inclusief banden en alles. Twee spaakvelgen opnieuw laten spaken is een heel stuk duurder dan €20,-:(
Misschien moet ik maar eens opzoek naar een losse schommelarm voorvork:?5 oktober 2017 om 23:15 #122870Vlechtservice utrecht betaal je 35 aan spaken en 35 a/l.
6 oktober 2017 om 05:02 #122871Dan zou ik gewoon op zoek gaan naar een andere Ciao 🙂 Voor het geld dat een C7 met starre voorvork oplevert koop je een heel mooie Ciao met schommelarm en hou je nog geld over ook?
24 februari 2018 om 09:26 #713869
AnoniemHello, I have two Vespa Ciao which I have tried to match with the list of frame numbers. But I must be stupid because I can’t see it. Can anyone please help?
First: C7E1T*203770*
VoV1392 (Swedish proof for mopeds)
Second: C7E1T*1241695*
As I said: I’ve tried to match them to the list but I need help 🙂
27 februari 2018 om 20:01 #718291Hi, i think we can make a good match if you give us some pictures as well. I can see some similarities with the numbers in our list but we could confirm if you place a picture.
Have a look at:
If you place a picture in this topic together with the numbers you mentioned earlier i think we can help you.
8 augustus 2019 om 09:38 #7891902 weken geleden hebben we een tourtje gereden met de oldtimers! Zie onderstaand de aftermovie
Heb je het gemist? In 2020 gaan we ook zeker weer, hou het forum in de gaten.
8 augustus 2019 om 10:56 #789191Leuk filmpje!
Lekker rustgevend muziekje ook 😉
8 augustus 2019 om 13:50 #789198Leuk filmpje
Steven Spielburg zou er jaloers van worden.En inderdaad een rustgevend muziekje.
Wel jammer van de orde verstoring bij het vredes paleis en de snelheid overtreding bij het Joegoslavië tribunaal.Dat jullie niet even met poep gegooid hebben op het binnenhof…….
Want per 1januari 2020 is er een 2 takt verbod in Den Haag.8 augustus 2019 om 14:03 #789200Filmpje zit leuk in elkaar, tourtje ziet er ook geweldig uit 😁
Welkom op ons forum!
Breng een bezoekje aan mijn Ciao project. -
