:: Hello all
Home Forums Algemeen Even voorstellen Hello all
  • #791234
    Joe
      Hello from the United States. I’ve been reading on the forum for a while. Here are some of my bikes and projects.
      #791235
      Joe
        #791236
        Joe
          Bravo chopper
          #791237
          Joe
            #791238
              That are some nice bikes with some unique modifications:thumb
              Maybe you can make a perso, so you can tell us a bit more about it.
              #791239
              Joe
                Thanks, when I get some time I’ll start one. I wasn’t sure how well the English would translate.
                #791240
                Crullie
                  Wow great stuff 😛  Seeing some strange cilinder heads, would be nice to learn about the american way and parts you use. Please tell us some more about it :thumb
                  TICKLING BARN
                  #791245
                    haha that chopper AWESOME!!!!!!
                    Joe
                      Thanks man here’s a video of the air ride
                      #791254
                        LOL and wow.
                        Real cool that air lifting thing 🙂 The air horn is great to impres.
                        Love the big cilinder head,s.  CNC milling?
                        Like to see more about the technical chance,s you made.
                        Keep it comming :thumb
                        #791255
                        Joe
                          Yes the heads are cnc machined. The air cooled heads work awesome. Unlimited wide open throttle blasts without over heating and seizing. I rode wot at an incline for a few miles and only got to 375 degrees F plug temp, where the same setup on a malossi head got to 425 before I let off to keep from seizing.
                          #791258
                            Hey Joe. Welcome on the forum. Hope you like it here. Great bikes you’re showing! What are the engine setups?
                              Air ride suspension on a bravo chopper, thats sick dude:thumb
                              #791265
                              Joe
                                the si and grande both have malossi 43mm kits, stock cranks with the duration opened, stock cases with the intake opened to 13mm, carbs bored to 13mm on a proma circuit pipe.
                                The ciao is a ported stock cylinder, with crank cutting, intake and carb at 13mm with a modded Yamaha yz85 pipe.
                                the kinetic(light blue bike which is a Vespa clone) is a dr 43mm kit with a reed case half with a yz85 reed block and ‘mikuni vm22 carb. Homemade pipe on that one.
                                the bravo is 46mm polini on a stock case half and a reed case half with a Honda dio reed block. I started out with a 15mm delloroto carb then bumped up to a 19mm clone phbg. But may swap to a mikuni vm19 that I have. I’m still playing with this bike it’s not tuned yet. There is a technigas qtre pipe on this bike.
                                I run modded 50cc gy6 variator pulleys on all them.
