:: Has anyone used the Sprocatti Ignition Plate for CDI Case?
Home Forums English General questions Has anyone used the Sprocatti Ignition Plate for CDI Case?
  • #144369
    bonsaismith
      looks like this
      i have one
      Here is the link:
      http://www.sprocatti-motori.com/piattello.htm
      i’m just trying to figure out if anyone has run one and where a good place to start in setting the rotation of the plate properly.
      i’m running the 46mm pinasco kit, polini speed case, 17.5 Dellorto PHBG.
      thanks!
      #146144
        I’ve installed it once on the Ciao from Bartje.
        It has no markings what the baseline ignition point is so you will have to measure it yourself. This is quite a time consuming process.
        The quality of the plate is not very high, the fit is bad and you probably have to modify it a little before using it on your moped.
        I would say, invest in a scooter ignition. As I remember correctly “waarom?” has one for sale which is plug and play !
