:: GZ: Disc for rotary slide engine
Piet30Topic starter
Hi,
is here somebody who can produce the rotary disc for an rotary slide engine like Sprocatti?
Or any idea where to get this type of disc?
Hello Piet, you can probably get it from gab pei. He also sold a cnc rotary disc carter. I got one and it seems the same. You should also find the disc taker for the crank there.
Good luck!
Piet30Topic starter
Hi Brandweer, thanks for the advise.But gabpei does not have this disc with 100mm diameter.
Still looking for it.
