:: Gianelli Fire ?
Home Forums English General questions Gianelli Fire ?
  • #144402
      Hi, I would like to hear your experiences with the Gianelli Fire exhaust.
      What character does the exhaust have and for what cylinder size, vario or mono should it be used.
      Is it comparable to the Proma CC ?
      #146360
        http://vespa-ciao.nl/forums.php?m=posts&q=15542
        Its a nice exhaust, speed i think is comparable to the proma, but the boost comes later. Sound of the old version is very nice but the ‘silencer’ is small so it will quickly become noisy.
        #146362
        misterd11
          it is comparable to the Proma CC, but the boost is less hard with the fire! And top speed is little bit lower! The cc is more fun, and the boost is great!
          But the fire is better looking!
          #146364
          tnerual
            Once Proma, always Proma. However, the old Fire version performs very well too!
            #146365
              Also ook at this topic of the results from this years exhauststest. Remarkable is the difference in score between the different kind off cylinder bores. It is said and i’ve heard on the bigger cylinders it wil perform not that well, but untill the 43mm it will go very good as for top speed. Definately better then a Proma cc in the 3 personal test I’ve had.
              Therefor I will make sure to test this exhaust again on a bigger bore, because i will have more testresults. 😉
              Also ther is no difference in the old or new version of this exhaust, but maybe there is a slight differnce between the Ciao and Si model. This is because the front of both pipes is different in lenght. It’s good to know. All my test were with the Ciao version.
              #145916
                Hi Martino, that helps a lot :thumb
                I think that I will order one, JMPB has a special price at the moment. 🙂
