:: Gearing with front variator and rear clutch?
Home Forums English General questions Gearing with front variator and rear clutch?
  • #144415
    Coolvette
      I´d like to calculate the theoretical topspeed of my machine using the following facts:
      RPM, will be measured by an RPM meter.
      Rear wheel gearing, is a known fact.
      Rear wheel cirkumference, easy to measure.
      These facts are easy to use but I need to know the changing size of the variator and the clutch.
      The variator is an Malossi Multivariator and the clutch will be an stock replacement.
      The belt gearing will obviously change as the variator and clutch works and the belt changes position.
      How can I calculate that gearing?
      #145733
        I wrote a How-to on that subject some time ago, you can find it here: http://www.vespa-ciao.nl/page.php?id=353
        #146120
        Coolvette
          Great, I will have a look at that.
          Thanx.
