:: Gasket for 2-gear gearbox
Home Forums English General questions Gasket for 2-gear gearbox
  • #144328
      Hi, is there an expert who knows where to get the gear box gasket for a Bravo 2-gear ? 😐
      For this one
      #145514
          hey, cool, but it shows 25,- delivery cost :((
          #144975
          wim v8
            You can cut it from a big leave of gasketpaper.
            #145487
              yes, that is finally what I need to do.
              Can you recommend a gasket paper with good function for gearbox oil?
              #145461
              wim v8
                No, you can better ask that question at the shop were you buy. Only take the same thickness.
                #145452
                Jasper-Grillo
                  you can use liquid gasket?
                  #144846
                    mmh, then I do not have the thickness of a paper gasket (maybe 1mm) between housing and cover.
                    The cover then could be too tight on the housing and squeeze the gear wheels in the bearings.
                    #144946
                    Jasper-Grillo
                      you can put some on the old gasket. Then you have a oil-tight seal with the original thickness.
                      #144947
                        Originally there was only a thin gasket beeing used. 0,3 max 0,4mm.
                        I’ve just found out, i can lasercut gaskets at my workplace. I will try to extract a complete functional gasket of one of my 2-speeds. So i can duplicate these gaskets in any desired thickness, but the 1mm seems way to thick in my opinion.
                        #144651
                          🙂 was a rough estimation. I measured the thickness of the old gasket, it is 0,3mm.
                          Laser cutted gasket sound great. :thumb
                          Jasper, yes that could work. But when I opened the gear box the old gasket was sometimes glueing on the housing and sometimes on the cover. So the old gasket is splitted in some areas and cracked many times. No chance to use it again.
                          #144650
                          Crullie
                            120grams a square meter, Xerox A4 printer paper will do just fine :thumb
                            Its al about the weight of the paper what the density determed and offcoure a flat surface.
                            TICKLING BARN
