:: Freakz SI Perso
Home Forums Perso’s Projecten Freakz SI Perso
15 berichten aan het bekijken - 76 tot 90 (van in totaal 296)
  • #711873
    MofaFreak87
      i started to mount everything together. great feeling when everything fits.
      #712360
        Nice detail that lubricate hole for the bearing. Do you also have to heat this crankcase for assembly? That extra space along the crankshaft is a good idea. 🙂 How are the kickstart teeth mounted on the shaft?
        #712519
        MofaFreak87
          The crank with the teeth is pressed into the minarelli crank.
          An no i don’t need to heat the case. There is 0,005 room between bearings and case.
          This is why it is a prototype. Next Time i make it smaller so that i have to press the bearings in. First of all everything has to fit and work, if I’m happy with that later I will make another case „Mark2“
          #712638
            I see that you have enough matrial to go to “Mark 8” so that will be fine. 😀
            If you use a paper gasket then you can heat the crankcases. Will A press fit work in the crates ?. Because you also have to press the bearings around the crankshaft.
            #716900
            MofaFreak87
              its the same like in our standard cases.
              The material will be enough for maybe a Mark4 but i dont know if i want to do that 🙂
              even one carter is pretty much work.
              here some pics from today
              #717021
                Nice, I in injoyed that 😀
                #721839
                MofaFreak87
                  Just started with the sheep metal work.
                  I think i will weld this on the Si Frame.
                  I hope that makes a not too big look at the front when its finished
                  #721842
                    You hit two flys, whit one blow, one, you dont see te radiator. Twoyou get a ferry strong frame. 😀
                    #721953
                    Joukel
                      Wow that looks nice! Keep up the good work!
                      Oldtimer fanaat
                      #721970
                      AA-T
                        Are those plates to conseal the radiator or do they also serve a different purpose?
                        Interested to see how it looks when welded to the frame.
                        Keep up the good work :thumb
                        #722214
                        MofaFreak87
                          @zevenenergie: thx, you were right. it will hide the radiator. but it wont stabilize the frame because i only want to make some small weldings.
                          @joukel
                          : Thx mate.
                          @AAT: first of all i wanted to hide the Radiator a bit. otherwise it looks like a racing bike.
                          in my opinion it isnt hard to get a powerful engine, its more heavy to get a good working engine where you dont see it on the fist look if its heavy tuned.
                          The second reason for the sheets are to guide the air into the radiator.
                          but we will see 🙂 this is just the first try, i also hope it will look not that bad at the end hehe
                          #724353
                          MofaFreak87
                            Fits more and more like a glove.
                            Without the cooler its pretty empty space.
                            with the cooler mounted it looks pretty good i think
                            #724372
                            AC RACING
                              This is one of the best projects I’ve seen for years!  Keep up the good work!
                              #724441
                                Its getting there. Cant wait to see/hear it run:thumb
                                #724609
                                  When reading and viewing this project, it’s screams for a bigger faster cylinder. 😈
                                  When you’ve tested this Marc-one and this resulted in a positive run. I’m curious to know which cylinder you will choose next?
