:: Freakz SI Perso
Home Forums Perso’s Projecten Freakz SI Perso
15 berichten aan het bekijken - 31 tot 45 (van in totaal 296)
  • #500624
    MofaFreak87
      @crulli: thx mate, like I write before, it is not 49cc.
      It is 68cc with 47mm diameter and 39mm stroke.
      @brandweer: this is what i First was thinking about but for the first tests I gonna buy a BGM standart membran with a stuffer.
      Now it is important for me to bring the engine ready for the first run.
      After that I will modify everything part by part.
      @ buxy jehaaa this would be great :thumb
      #500629
      MofaFreak87
        today i got my BGM membran. its a little bit bigger looging but in real its a lot bigger.
        I normally dont need that because i want to ride it with max 19 or 21mm Carb but its good to have some reserve.
        #500631
          Verry nice,:thumb
          #544635
          MofaFreak87
            WHOOP WHOOP my Mill arrived and i immediatly started with the Pump 🙂
            Verry nice i can tell you
            #544659
            Tiesman1986
              nice !!  Kickstart rulezz 🙂
              #544713
                WoW………. gongratilations, this is wonderful 😀
                No moore limi ta tia tions (I,m biginning to stutter) :mrgreen:
                Can you send more pictures? and details  of the milling machine?
                #547944
                AA-T
                  Pictures are working again, I edited your post so your pictures are showing.
                  The milling machine looks very nice! Must say I’m a bit jealous 😉
                  #552222
                  Crullie
                    WHOOP WHOOP  😎  Now the real work is coming  😉
                    TICKLING BARN
                    #553390
                    MofaFreak87
                      jeahhhh you are right
                      @zevenenergie: you still want more Pictures of the Mill? Its a Bernardo FM55 HSV
                      @AA-T: Big thx for fixing 🙂 and thanks for the flowers ^^ i also love my new Mill.
                      I would liked to had it long time before, it makes everything easyer i would say.
                      Doesnt fit? Mill it. Doesnt look good? Mill it :mrgreen:
                      and it goes on with the pump. just tested the big “ausdrehkopf” from the Mill. Works great but i still have to mill more away.
                      If i can leave today work a litle earlyer i will start with the Membran inlet WHOOPY
                      #555359
                      AA-T
                        That’s a big piece of aluminum for your pump. If you Mill some cooling fins into it you don’t even need a radiator  😆
                        How will you mount the pump onto your engine? And will you be using a ratio?
                        The cilinder is probably able to reach quit a high RPM. Don’t know if it’s necessary for your pump to make the same number of RPM. Maybe it could even be bad for it?
                        Don’t know if scooters use a ratio, but you might wanna look into it.
                        #555558
                          If found it on the internet,
                          Die Bohr- und Fräsmaschine FM 55 HSV überzeugt durch ihre stabile Konstruktion und einfache Handhabung. Die Grundausstattung beinhaltet alle wichtigen Zubehöre (3-Achs-Digitalanzeige, Frästisch- vorschub, Hubmotor, Zentralschmierung, Kühlmitteleinrichtung, LED-Arbeitsleuchte, Graugussuntergestell mit Kühlmittelrinne, Sicherheitseinrichtungen nach CE-Norm, …)
                          Nice I want one 2 😛
                          #556043
                          MofaFreak87
                            @AA-T: the ratio on scooter is 1:1 and im going to do it minimum 1:2 ( 2 Engine 1 Pump)
                            High RPM is not what i want. max 10k smooth going forward.
                            #556225
                            AA-T
                              You actually want your pump to rotate faster than your engine?
                              If so, why do you think that’s necessary?
                              Or do you mean it the other way around?
                              #563331
                              MofaFreak87
                                Oh sorry thx for attention 🙂 no i dont need the full speed of the Pump.
                                i mean 2 rounds at the Engine is 1 at the pump. So half turns as at scooters.
                                i will reach that the pump is pumping enough for reducing the heat and the so that the belt is not slipping at higher rpm. otherwise the belt will not live very long.
                                i think the polini LC pump is quiet smaller than my selfmade, so the power of the pump should be also higher, but if i need it? no i dont think i need it but to have more is better than too less hehe
                                jesterday i tried to learn a bit from my mill. fact is i need better milling cutter.
                                i also bought a extra wet vacuum cleaner just to suck the wet shavings off of my mill 🙂
                                #564837
                                AA-T
                                  You don’t necessarily need the coolant every time.. It allows you to run your mill at a higher RPM which makes everything a little bit easier. But as you see it can leave quit a mess 😉
                                  Doing some research into the correct RPM for the combination of material en width of your cutting tool could be helpful.
                                  Try to keep it as low as possible, and only run a higher RPM on the last run for a smoother finish.
                                  If you take away a ver little amount of material on your last run, let’s say 0.1 to 0.2mm, it will also give a smoother finish.
                                  Also, I don’t know how to say this in English so I’ll explain it. Your cutting tool turns clockwise. When you run your material from the left to the right it will give a different result in the finish than when you run your material from the right to the left.
                                  When your cutting away big chunks of material it doesn’t really matter, but on your last run it can make a big difference in how smooth your finish is.
                                  The cutting tools you are using don’t look that bad, so the above advise might help you a little bit. And maybe you already know all about it 😉
