- Dit onderwerp bevat 295 reacties, 22 deelnemers, en is laatst bijgewerkt op 6 jaren, 6 maanden geleden door MofaFreak87.
23 mei 2018 om 14:15 #774826
A little bit rich but otherwise a happy motor 😀
TICKLING BARN23 mei 2018 om 20:17 #774837jeah, this is better than too thin.
here my next problem. i drove now 59km and i have the problem that my crankshaft goes 0,3mm axial.
i will take appart the engine and make a bushing for the crankshaft bearing.
the tolerances were to less because i assambled the engine so often to check if everything fits good.that is the problem of a prototype 😀
so tomorrow take everything apart and by the way i can modify the cooling system.
because when i drive evenly 70-80 with very low throttle the heat is getting up again over 100°Ci think the waterpump has to pump more water.
23 mei 2018 om 22:04 #774840Maby the coling belt is slipping, You could put some stiky stuf on there and try it again to see if this is the case.
27 mei 2018 om 16:27 #774928jeah, i checked it buw everything is fine.
i think the cooler is not the best place and maybe not big enough.jesterday i assembled everything together and now it runs fine.
i also made a cover for the electric. not the beatifulst but it works.
after the vct i can make a nicer onefrom tomorrow on it time for the back bag holder. making a nice back fender for the bike sign and close the hole engine frame so that it isnt so noisy 😀
29 mei 2018 om 13:22 #774972Are you ready?
29 mei 2018 om 21:02 #774981almost.
now the last special Part 🙂30 mei 2018 om 08:42 #774990Nice a douce tank for a cool evening 😛
Kidding offcourse
TICKLING BARN30 mei 2018 om 10:00 #774994An extra tank….. Thats the wet dream im having fore a long time 😛
Dit you make theyour self?
And how dit you fix your cooling?30 mei 2018 om 11:53 #775001@crullie: its the Tank for the vodka whisky and other stuff 🙂
each time we have a breakdown you have to drink a shot hehe
@zevenenergie: nono, its bought on ebay 🙂jeah the cooling is still a problem. i have a solution only for the tour but for later i have to make a better solution. you will see it on friday.
i will mount a “Rippenrohr” which is made out of stainless steel and 25cm long.
i hope it will give me 2-5°C
30 mei 2018 om 12:17 #775002Have you tested the thermostat ?, in a pan with water and termometer on a fire, cook it ! maybe replace the termostat for a other one what opens 10 degrees earlier ! Or the termostat does not open all the way ?
Mayby you try whitout the termostat just to see the differens 😎TICKLING BARN30 mei 2018 om 13:04 #775005the thermostat is already out, now the system is complete open.
if i drive 40km/h i can cool down to 86°C but if im driving a bit faster the rpm is at 6000, and the temperature will heat up over 100°C again30 mei 2018 om 13:32 #775008So the termostat is not the issue, is your time of ignition on the right spot ? maybe you timed it a little to early ?. I know you will set it on max 😛
Its not a lean gas mixture because your head and piston where pretty black. How is the sparkplug showing ? and have you used the right sparkplug ?
Or maybe it is just a little overheating because of the break-in period, when cilinder and piston are becomming smooth the heat will go lower but I think its not the problem.I will think with Ya
TICKLING BARN30 mei 2018 om 14:07 #775013Ignition timing is on 17°
sparkplug is a ngk with 8 heat number, so its pretty cold, maybe a bit too cold because the last one died a bit to early.
The zylinder looks pretty smooth from the inside. its almost driven for more than 100km.
the one and only point which i didnt changed is the waterpump.
maybe its that.
you know what, there is not enough time to check everything.
if i will cook up i have to quit the vct and i didnt reach my goal.
but i think i will find a solution 🙂 the worst case is that i have to put water over the watercooler while driving haha30 mei 2018 om 14:51 #775014*Ik think that the cooler is big enuf but the air cant flow.
The way i see it, is that de radiator is now not bigger then the exit openings.*And the frond of the hood is working like a spoiler, so at higher speed only the half of the radiator is in the wind.
* you can flow all nipples for better flow.
31 mei 2018 om 19:19 #775061So now its time vor VCT. the last things are done.
my tank is leaking at one point where the gas tap is weldet. it was the wrong material, but it will work fine with some silikon hehemy garage is looking like a bomb explodes, no time at all to clean up for more than 3 month.
i can tell you im so happy that its almost ready.
some things have to rebuild because it was made to fast and the quality is not that as i want.here some pics of the moped and my garage
What a huge mess uhhhhh
