:: Freakz SI Perso
Home Forums Perso’s Projecten Freakz SI Perso
15 berichten aan het bekijken - 1 tot 15 (van in totaal 296)
  • #284765
    MofaFreak87
      Hi friends,
      there is everytime the same problem for me, the zylinder you get for ciao citta and Co are pretty bad because of the tolerances and the Material.
      And a zylinder from scooters doesnt fit at all without any massive problems.
      So what to do.
      get some F**** Aluminium and do it yourself 😀
      pretty easy to say but not easy to do as well.
      my try is it to build a watercooled KICK engine which runs on Minarelli parts but fits in a normal or for the first prototype in a selfmade frame.
      so what should i tell you more. Pictures say more than 1000 words 🙂
      49cc is a BIG lie
      and here i am actually. now i have to wait for a variator kit for 17€ …. whoi thats cheap stuff i tell you….
      #500585
        That’s a very nice project:thumb
        Looking forward to the end result.
        #500586
          Wow …..
          That is having guts.:thumb You are on your way to eternal fame.
          I would really like it if you bring this to a good end.:@
          #500587
          MofaFreak87
            this is what iam looking for.
            the Si is normally my all day bike and this has to stay that way 🙂
            If the parts fits very good at least i can change them to some with a little more power harrrr =):thumb
            #500588
              I’ve seen your project also on PMT.de and it’s called VCT SI Das Beast. Are you also planning to drive this with this comming VCT?
              #500589
                Very interesting project, keep us updated :thumb
                #500590
                MofaFreak87
                  @martino: yes indeed I want to drive it on the vct. It has to, because there is no other engine ready :!
                  @will: i will do. :thumb
                  #500594
                  MofaFreak87
                    today the cooler arived. perhaps a little bit too high but for the first try it should be perfekt.
                    and no it doesnt belong to the ciao, i was to lazy to go out of my warm garage 😀
                    the vario is really tricky, this is only for the first test. i think i have to turn the hole backside of the vario on my lathe new and make an adapter so that it fits good.
                    #500595
                      Why the choice of a Piaggio/Vespa variator if you can also make the Minarelli fit? This can be much cheaper and easier aswell.
                      #500596
                        How you gonna fix the cooling?
                        Cause a pump with accu will not last a whole Vct tour.
                        #500597
                          Nice nice, Doing well:thumb
                          How do you ensure that the crankshaft bearings are aligned?
                          #500599
                          MofaFreak87
                            @Martino: the minarelli is 4mm deeper and you see that the space on the shaft isn’t a lot.
                            This is just for the first test. When the engine is running I will make my own vario.
                            @speedbuxy: this is true. I build the waterpump by myself.
                            It will work like the pump from the Polini lc Kit. Same principle.
                            Zevenenergie: look at the pictures, there are two diameter going together. It’s perfectly aligned.
                            #500600
                              Ok, I see now,:thumb
                              Dit you weld the brak holder on the fork or dit you durafixt it?
                              Compliments compliments.
                              #500601
                              MofaFreak87
                                Yes it’s welded to the fromt fork 👌
                                #500605
                                MofaFreak87
                                  now i drilled the M7 bolts and i started with the kick side.
