:: Expected speed from my setup
Home Forums English Pub talk Expected speed from my setup
  • #147460
    eran_k
      Hi everyone,
      With my Si, i reach the end of the km teller (60 km/h) and dont know my max speed.
      From your exprience what speed can i expect with my setup:
      Piaaggio Si montecarlo electronic kickstart
      Motor: DR43 with stock head,ports matched to case,inlet enalrged and drilled to 13mm,13.13 carb with #74 jet and hi flow filter
      Exhust: Proma circuit
      Variomatic: Mallosi Multivar,7.5 gram rollers, 100mm rear pulley,rear spring still stock (got the yellow spring but not installed yet)
      I’m on the heavy side (~115kg) so this can effect my top speed as well :bloos
      thanks
      Eran
      #148040
      Jarco
        I think about 70 – 75.
        But like to here someone else his opinion. :thumb
        #148041
        aapie90
          I think about 65 km/h
          because of your stock ports (no boosterports)
          #148042
          Jarco
            I dindt see that, good question.
            Is it the normal DR43 or the DR43 EVO ( with open boosters. )?
            I asumed the 43EVO because you say you matched your ports to your case?
            EDIT: I see it in your singnature: EVO power! 😀 So i stay with the 70 – 75
            #148043
            eran_k
              Yes it’s the EVO, and i did matched the “Finger ports” to my carter as well
              #148039
              Blacklisted
                Is it okey if i borrow the thread?
                Simonini sideinleet,
                19mm dellorto
                Malossi big deps
                polini vario
                90mm clutch 🙂
                Malossi too bad or Simonini calibrata 🙂
                What do you guys think that the topspeed might be?
                From Sweden
                #148038
                pepko
                  @ blacklisted: we have a special topic for this: the “hoe hard zal dit gaan topic”
                  I think the topspeed will be around 85/90
                  #148035
                  Blacklisted
                    And where do i find that one? 🙂
                    From Sweden
                    #148036
                    Jarco
