:: Exhaust for Polini 46mm on Polini Speed Engine?
I currently have an old Sito Citypower that needs to be replaced.
Tested a Gianelli City Power but it didn’t clear the spokes on the rim or the pedals, which it did using an original carter and DR 43mm ?
A Leo SP would have been nice but they are almost impossible to find at decent prices (or at all…).
Is the Gianelli Fire OK? then there would at least be no clearance issues (I don’t have a vario but the Polini 46mm has a lot of low-end power so even if the Fire is a high-rpm exhaust it should work OK)
JelleModerator
The gianelli fire makes a lot of noise, maybe you can find an Leovinci Handmade (not the long version).
I drive with it on a speedengine with an 46 mm polini and i like this a lot.
Do you have a picture of it?
Polini top one is now the best I have tested.
Next week hopefully a 43mm polini set to test too.
