:: Engine not idling
Home Forums Techniek Mechanisch Engine not idling
  • #821560
    Michael
      Hi guys,
      I bought a Piaggio Ciao P a few years ago. It had on it a sha 12.12 with 42 jet. The problem is that this engine don’t want to idle correctly and it’s really annoying. I set the ignition points to 0.4 mm as in the service manual, the spark plug is new, it’s a bosch super with 0.6 mm gap measured by me. I serviced the engine (complete disassembly) and everything was fine. Any ideas how to fix this shit?
      Mihai
      #821562
      Joor
        Maybe a wrong jet or some false air.
        1
        #821563
        Wim
          Yes indeed.
          Try the main jet.
          The jet database says 48
          https://vespa-ciao.nl/sproeier-database/
          But maybe your Ciao had an other set-up.
          P.s. “snor” in de database = 25km/u moped and
          “brom” in de database = 40km/u moped.
          you already have the moped some years you say.
          But has it never idled properly?
          Or have you ever changed anything about the set-up?
          1
          #821566
          Michael
            Yeah, actually when iI got the moped it won t start, it was the flywheel. Then since I repaired it the enigne was running really nice at speed but it never idled properly.
            The setup: brom crank and carter, oringinal piaggio cylinder with aftermarket piston and piston rings
            That’s all I can tell you. But even if the jet was too small I think the moped was supposed to idle, am I right?
            Mihai
