:: Driving Belt for the Superbravo variator
Home Forums English General questions Driving Belt for the Superbravo variator
  • #144259
    ludde863
      Hello.
      I have a ciao and im going to put on a superbravo vario on it. But I don’t know at which size the driving belt should be?
      And another qusetion, with the superbravo vario, will my ciao reach top speed with that vario? My setup is 70cc malossi, Polini sp, 13mm dellorto and so on.
      Sry for bad english
      #145836
      niek1992
        you’ll need an belt wich measurements are 13×950(for the 90MM clutch) or 13×975(for the 100MM clutch).
        if you’re gonna use the stock variator, it will be restricted, it only works pretty on stock setups or semi-stock setup.
        you should buy an malossi or polini variator. WAY better then the stock one.
        #145837
        ludde863
          Thanks for quick answer.
          I know it’s restricted but I have one that is’nt restricted. I hope it will work okey, im goin to buy a malossi when I can afford it.
