:: Drive belt width Fox clutch
Home Forums English General questions Drive belt width Fox clutch
  • #144359
      Hi,
      I just tried to find a drive belt for using a Fox clutch in combination with Malossi MuVa.
      If I use the standard belt width of 13mm my max. outer diameter on the Fox clutch is about 97mm when the clutch discs are complete closed.
      Is it possible to use a 15mm width belt in combination with the MuVa?
      #145241
      misterd11
        yes you can drive with a 15mm width belt! Good luck!!
        #145455
        niek1992
          jup, you can. but you’ll notice that the drive-belt isn’t exactly on the lowest point at the malossi variator.
          #145651
          TJOEP
            Or consider to make the width of the drive pully smaller in a controlled manner. E.g. With a mould in the vise or hydraulic press
            #145747
              I am using a 16mm belt in combination with a Minarelli vario. I’ve made a slightly longer “glijbus” so the belt gets to the lowest point in the variator.
              pm me if you want pictures or anything.
              TJOEP
                Javad :
                I am using a 16mm belt in combination with a Minarelli vario. I’ve made a slightly longer “glijbus” so the belt gets to the lowest point in the variator. pm me if you want pictures or anything.
                The fact that you’re using a Minarelli vario is already worth showing the pictures here, or in a sticky.
                I’m actually very interested to see them. The Fox clutch and drive pully also fits a Minarelli axle and vis a versa. So it may open up new opportunities…
                #146487
                  it has nothing to do with the belt width but maybe is interesting. I bought a Malossi variator for Minarelli engine. Outer diameter of the vario is 97mm.
                  I used a back disc from Motoforce and milled the cooling ribs away.
                  Then milled the anti turn safety profile from a Ciao Malossi Multivar bush into the Motoforce disc.
                  After that grinded the bush profile into the 97mm Malossi variator roller plate.
                  Then checked with a standard 13mm vario drive belt. Related to the krukas thread length there is enough thread length left for using a 15mm or 16mm width drive belt. 😀
