:: DR EVO vs. Polini 46mm
Home Forums English General questions DR EVO vs. Polini 46mm
  • #144465
    Szasza
      Hello,
      which one is better?
      best regards
      Szasza
      #146846
        There is no such thing as better.
        Both have their own performance and reasons to buy.
        #146847
        Szasza
          of course, I understand
          Which one to get more?
          #146848
          SuperSi
            more what?
            #146849
            Szasza
              power 🙂
              #146850
              Kinderbrueno
                Low-end or High-end?
                #146851
                  Maybe a bit more context is handy..?
                  What setup do you have in mind?
                  #146604
                    They need different carters, and different exaust,s to performe at best.
                    On a standard tuned carter the 43DR runs about 70km to 80 at best.
                    And it wil only cost you 75,- euro,s
                    The 46polinie needs a speed engine($$$$$$) or a evo engine($$$$$$$$$$$$$).
                    and wil run 80km with a good exaust.
                    Bit more power at low rpm.
                    The DR 43 is a ferry good cilinder,and lasts forever.
                    The 46mm polinie is also good, but has a piston that wil sometime,s crack.
                    I would take te DR43MM for its power, price, and durability.
                    And take the 46 polinie for its power and potential, fore if you tune it well, it can become realy fast.
                    #146852
                    12V
                      I have tested the Polini 46 mm and the DR 43 mm on the same moped with the same setup. The difference is small, the DR is better at over revving than the Polini, i had a little higher topspeed with the DR. The Polini has more power all over the whole range otherwise, but only a small amount.
                      If you have an original engine case, i would save the money and extra work to fit the larger cylinder, and go with the DR.
                      regards, Carsten
                      #146857
                      Szasza
                        Thx Guys!
                        best regards
                        Szasza
