:: distance cylinder studs Sprocatti
Home Forums English General questions distance cylinder studs Sprocatti
  • #144283
      Hi,
      does anybody know the distance between the cylinderstuds of Sprocatti block with 4 studs ?
      #145969
      barry
        You can measure the 4 holes from a scooter cilinder. It’s the same.
        #145970
        MHR
          All the scooter engines have different studs. Minarelli And Morini engines are 100% different from each other.
          I think it’s the same as the Simo 2007 engine.
          #145971
          .-{2F4OV}-.
            A minarelli cilinder fits the engine.
            #145972
            MHR
              That means Morini and Piaggio won’t fit. Unless you kan make the holes for the studs larger.
              I Thougt Pagano did this also to his TCR kit.
              #145973
                Minarelli has also different engines. So of which engine do you speak Sil?
                The Minarelli horizontal one? In this case the distance is 50mm between the centre of the studs.
                #145974
                tnerual
                  That block is kitted with a ParmaKit 50mm for AM5/6 i thought? So I think you have to measure those studs? Or am I totally wrong?
                  #145975
                    aaah, assuming that a 2007 Simo has the same stud layout like the Sprocatti. Would a distance of 44mm from middle stud to middle stud be ok?
                    Or what is the distance on a 2007 Simo block?
                    #145540
                    tnerual
                      but, i repeat, i think you have to ask someone with a moped equipped w ith an AM 5/6 engine?
