:: Different Variators
Home Forums English General questions Different Variators
  • #144458
      Hi, for my Oldtimer I like to use an original variator.
      Now I find two different versions of original variators, one with 5 rolls and one with 8 rolls.
      The weight of the rolls is about 8,5gr each, in both version variator. Means the total roll weight in the 8 roll version is 68gr and in the 5 roll version it is 42,5gr.
      I assume, that one version is for brom and one for snor type of moped.
      Could somebody explain the difference of both type variators?
      EDIT: And what is the difference to the Polini Utha variator (JMPB link)?
      http://www.jmpbonderdelen.nl/vespa-ciao-si/motordelen/variodelen-vespa-ciao/polini-utah-variateur-vespa.html
      #146735
        I once bought an original Italian Ciao with Variomatic and that one had the 5 rolls. It also had 90mm discs and the most rare type clutch and a 11.5 to 1 transmission.
        This ran just about 45 to 50 km/u.
        Further i have no clue why there are these different types…
