:: Different electronic carter flywheel models
Home Forums English General questions Different electronic carter flywheel models
  • #144396
    Hebbe
      I have two different flywheels that both are from Piaggio and for what I guess electronic ignition, as they look alike and are different from cp ignition flywheels. But as you can see they are different in size – the left one being noticeably thicker and, I guess, heavier (the right one is from a Super Bravo, the left I don’t know):
      Which moped is the left, thicker/heavier flywheel made for? It is not possible for me to try it right now but I guess it won’t work with my Super Bravo electronic ignition.
      #146347
        All electric fly wheels doesn’t have any holes in it for setting the ignition points. That is with the exeption of the Berini Fly wheels. So, left is for an pointer fly wheel and right for elec.
        Also another indication besides of the thickness of the outer diameters. Electric Fly wheels, don’t use any notch for opening the ignition points, so the inner center looks a little different.
        #146348
        Hebbe
          Martino :
          Thanks! I can see now that they are indeed quite different.
          #146280
            The left one is just the old type breakerpoints flywheel. They are mostly a lot heavier and have a smaller window.
