:: DEPS question
Home Forums English General questions DEPS question
  • #799771
    Chaos824
      a few years ago I bought the following off TimOo on the forum:
      43mm Pinasco DEPS cylinder tuned
      28mm exhaust port
      50km old Malossi DEPS piston
      Malossi 43mm cylinder head
      It was a project block with home made side intake reed-valve project block.
      I want to keep the pedals (for some unknown reason … I just think they make the moped so cool) so a side intake is out of the question. This morning I got another block in the post from Italy with a 13/13 and an Olyimpia 43mm cylinder P10.
      The plan is to match the new carter to the 43mm DEPS Picasso and order a 22mm outlet flange from somewhere.
      Without the side inlet will the 43mm DEPS run well with a 13/13 and 22mm exhaust or would I be better trying to find a suitable 28mm?
      Exhaust options are
      Leo HM
      Proma cannon
      Gianelli Hyper
      My ciao still runs with a 46mm polini P12 on polini Speed ​​Engine and gianelli fire right now, but soon the center stand will come off, once I manage to get a hold of an actual old timer center stand axle to support the side stand. Right now I use a bolt (maybe m8x115mm but I’m not 100% certain)
      Then I can use one of my better exhausts on my ciao too!
      Thanks for any input ^_^
      #799774
      Chaos824
        Cylinder in question.
        #799789
        Magnus01
          Since a few days I drive with a 43 Pinasco deps and with a single 13/13 and 22 mm exhaust manifold. I use a Simonini proline exhaust, jet 86 and no air filter. I like how it drives, it’s quite fast and works great with variomatic. With just a single 13/13 a 22 mm exhaust will work fine. Of the 43 mm cylinders the deps is one of the fastest there is, so its certainly worth it to modify cases for it!
          #799827
          Crullie
            This cylinder belongs with 2×13/13 or with a 19mm carburettor according to the corresponding descriptions but also runs with a thick jett without air filter on 1 x 13/13mm Carb :thumb
            TICKLING BARN
