:: Correct weight rollers for my set up
Home Forums English Pub talk Correct weight rollers for my set up
  • #147494
    rubymax
      Hello everyone,
      Soon I will get the new malossi multivar for my Piaggio SI. My current set up is:
      – DR EVO 43 with port matching
      – dellorto 13/13 + malossi air filter, widen carb intake
      – SITOPLUS exhaust
      – 90 mm vario with malossi contra yellow spring
      – electronic ignition
      What roller weights (16×13) for proper vario adjustment do you guys suggest me regarding my set up?
      Thanks in advance!
      #148240
      criminalmindz
        Approx 6-7grams
        #148259
        rubymax
          I think that 6 g rolls are already included in the new malossi multivar set, so it shuold be fine with 6 g?
          Is there any difference with roller weight according to my 90 mm rear disc?
          regards
          #148287
          sx3-swe
            What ratio do you have in your rear hub?
            #148288
            rubymax
              1 : 12.5, but I have already open a new topic because now I have different set up – look in forum> (English)> (English) The bar> Top speed according to the setup
