:: “Contactpunt vervanger” – why should I get one?
Home Forums English General questions “Contactpunt vervanger” – why should I get one?
  • #144397
    Hebbe
      http://vespa-ciao.nl/page.php?id=154
      What does it do/why is it better than regular points?
      #146353
      Kamelen
        Regular Contact “punts” gets overheated and burned pretty fast.
        // Sebbe@mnf
        #146354
          the new type “effe“ contact points have a built in failure.
          when youre engine runs over 6000rpm the little cam on the contact point will break en you`ll be stuk @ the middle of nowere.
          the contact point `replacer` is a cunning little device wich allows you run it without points.
          the drawback is that they get hot, and when they do, they will fail and no spark is generated.
          i also drove with them but also went dead for no aparrent reason.
          maybe you are better of with an “berini“ ignition, this is like electric ignition but with a light flywheel.
          and fits in a normal contact point engine, (se) (evo) (stock)
          #146355
          Hebbe
            ritze :
            Where can I read more about the Berini ignition? Where can it be bought?
            #146339
              you have to place an G.Z. (parts wanted) topic in the sales departement 😛
              they are pretty rare so, finding one soon is going to be a problem i thing,
              unless someone has one for sale right now but i don`t think so…
              link to extra info (berini) + scroll the page a bit
              #146325
              Hebbe
                ritze :
                I have a Kinetic Baghee/TFR (an Indian moped with a Ciao-like engine) with an ignition that looks exactly like in those photos. But unfortunately it is old and doesn’t seem to work properly.
                #146356
                  youre lucky, that is a berini ignition.
                  maybe, you wil get it running, or find an other blackbox for it.
