:: Compatible Crankshafts for Pinasco Flywheels
Home Forums English General questions Compatible Crankshafts for Pinasco Flywheels
  • #144353
    Coopering
      Hello,
      does anyone know which crankshafts are Fitting on a Pinasco Wheel?
      And I mean crankshafts for original carter, because I want to use the original inlet…
      #146492
      Crullie
        #146491
        SuperSi
          by pinasco wheel you mean pinasco flywheel?
          doesn’t every crankshaft go with the pinasco wheel?
          the crankshaft crullie says is specially made for the pinasco side inlet
          #145249
          Coopering
            Yes I mean the flywheel. Problem ist that the Pinasco flywheel is balanced.
            What do you think crulli, is the timing of the Pinasco krukas ok? I have this krukas in my Garage and the timing seem to be long..
