:: Ciao Mix another reason for sleeples nights
Home Forums English General questions Ciao Mix another reason for sleeples nights
  • #779367
    jacekniemiec
      Hello All Friends,
      I have ’98 Ciao Mix. The problem of this beauty is that the motor is not keeping the idilling RPM , and is not getting High/max RPM.
      Carb 12.10, main jet 43 ( I tryed 48, 37 – no change), carb cleaned in ultrasonic cleaner – all hols (Ideling too) are clean, new simmering on crankshaft, air filter – last letter S (not es), sparkplug new – gap 0,5mm,
      motor have symbol 11,5×7 (45 km/h).
      Is hard to start the motor and when it starts, motor is ideling for 10-15 second and all of the sudden it kills.
      I tryed diffirent carb, diffirent main jets, diffirent spark coil  –  nothing changed..
      What could it be?
      Calm medicine is not helping..
      #779370
        A Mix engine has only 2 weaknesses. The seal ring, which can just pop out. And the wiring of the coils behind the flywheel that has decayed. So if you can not find the problem, then I would definitely check this 2 first.
        #779395
        jacekniemiec
          You mean the seal ring behinde fly weel or the oil pump ? Couse I didnt change only the seal on the oil pump side …
          #779396
            behinde fly weel
            #779400
            jacekniemiec
              Than You, Zevenenergie for tip.
              The seal behinde the fly weel is new. What do yu think , how to examin the second weak point of Ciao Mix – the wiring of the coils ?
