:: Ciao Koppeling
Home Forums Algemeen Brommers algemeen Ciao Koppeling
  • #829789
    Schucha
      Hello everyone,
      My Mono-Ciao C7E1T
      original unmachined engine case
      63cc Polini
      13/13 carburetor with 66mm jet
      Malossi air filter
      Original Piaggio moped exhaust
      Original clutch springs
      new clutch pads
      new belt
      It runs very smoothly once it’s started.
      I have to ease off the throttle so the clutch can engage properly, and then gradually increase the throttle to reach top speed.
      The belt is properly tensioned, there’s no play and no sagging, and of course, no oil or other lubricant on the affected parts.
      The clutch pads are new.
      I’ve already tried harder springs (Malossi set), but then the engine revs even higher when starting, and the Ciao doesn’t move at all; it just revs up when stationary.
      Can someone please help me ?
      with this?
      Thanks and best regards
      • Dit onderwerp is gewijzigd 6 maanden, 4 weken geleden door Schucha.
      #829790
      niek1992
        Do make that video, but in the meantime, make sure the steel balls are properly touching the plate that bolts onto your crankshaft. Sometimes they’ll end up pinched in a wrong way, causing the segments to not move freely.
        Obviously stock springs would result in RPM engagement at around 2500rpm (or so i think). You’l probably be better off with Polini Blue, or the Malossi equivalent.
        #829814
        Schucha
          Please Check the link. Here you can See what i mean. The Clutch hast noch grip
          #829818
          Wim
            Sounds like the belt is slipping?
            Or the segments can not move free like niek92 said.
            #829819
            Schucha
              Belt is strong, Segments i am checking, also ordered a complete new Clutch will arrive tuesday i will let you know
              #829820
              bram0vitz
                Are you sure the belt isnt too tight on the clutch?
                Drivebelts need a tiny bit of play on them.
                beetje prutsen hier en daar
                #829822
                Schucha
                  It is very tight, so maybe thats the Problem. I will Check After Work
                  1
                  #829823
                  Schucha
                    Works belt was loose …
                    1
                    #829824
                    bram0vitz
                      Good that it is fixxed now 😎
                      1
                      #829830
                      Wim
                        Ah, dissapointing. Haha. We think with you a few days.
                        Next, make sure everything is oke and dubbelcheck three times, than ask   😉
