:: Ciao Kickstart Help!
Home Forums English General questions Ciao Kickstart Help!
  • #144315
    bonsaismith
      Hello!
      I recently got some kickstart parts and I need some help getting it all together and running. I’ve used this forum post to help me (Kickstart Overview) however i still need some help as i’m missing some parts. here’s what i have:
      [url]http://www.flickr.com/photos/11216572@N03/5512850524/[/url]
      http://www.flickr.com/photos/11216572@N03/5512851176/
      i do not have the parts for the pedal assembly or the chain.
      here are my questions.
      can somebody break down how the spring hooks up exactly? i’m asking this as i will most likely need to make my own or figure something else that will work.
      the part that hooks to the engine that has the teeth on it to hook the chain up to, it’s only supposed to turn very slightly as it moves towards the engine to engage the crank, correct?
      #146103
        Did you see this post ? [url]/page.php?id=198[/url]
        #146104
        BDW
          kick pedal
          I have a pedal set for you,you will just need a chain then
          #146105
          bonsaismith
            hansieb, i have been looking at that post and it has been very helpful.
            bdw, i would love to purchase your pedal set, does it include everything shown in this photo?
            http://www.flickr.com/photos/11216572@N03/5512591675/
            i can get the chain from fred at moparts, so that’s no problem.
            #146107
            BDW
              it has 2pedals,the axle,the spring en the sprocket,so everything from the picture
              #146108
              bonsaismith
                BDW, i sent you a PM. I’d like to buy the parts from you. you can email me directly at smith.r.bradley@gmail.com
                I can pay you with paypal if you want. let me know what works best for you. i put my address in the PM i sent to you so that you can calculate shipping costs.
                thanks!
                #146109
                BDW
                  i’ve didn’t received ay pm:?
                  #146110
                  tnerual
                    BDW :
                    Verwittigd man is er 2 waard: pas op met betalingen van ginder via paypal.. Je krijgt het geld, en dan stuur je het op.. En na 3 weken blijkt dan dat het geld van een niet-bestaand of ongeldig bankaccount verstuurd is, en is je geld weer van je bankrekening, en ben je ook nog eens je onderdelen kwijt..
                    Ik zeg het maar!
                    #146111
                    BDW
                      ik weet het,ik oe zoiezo niet mee met dat paypal gedoe,liefst doe ik het met een overschrijving,zo doe ik het al altijd,en er is nog niets misgelopen
                      #146116
                      bonsaismith
                        i’ve got another question.
                        i was putting a cylinder and piston on the kickstart crank and the hole in the conrod is too big…even for my 12 pin piston.
                        does the kickstart crank come with a needle bearing? which would end up making it a 10 pin (as 10 pin is much more common in europe and 12 pin is more common in the united states)?
                        #146117
                        Spulleke!
                          Yes is 10 pin comes with a needle bearing, so i think that is ur problem.
                          #146118
                          BDW
                            I will include one in my shipment to you 😉
                            #146141
                            bonsaismith
                              so i was able to find a NOS 10 pin piston here in the united states, and then i bought a 10mm needle bearing that fits nicely around the piston pin, however it still doesn’t fit in my conrod, the needle bearing is about 1 mm too big! i don’t understand how this could be. here is the needle bearing i bought: 10mm Doppler Needle Bearing
                              i’ll take some photos today and post em up, even though it’s pretty obvious that it doesn’t fit, but maybe you guys have seen a conrod like this before and have an answer for me. thanks!
                              #146142
                              pepko
                                this the one you need: CLICK
                                as you can see the needles are on the outside instead of sunk in it like yours. that’s why yours is to small 😉
                                EDIT: click2
                                #146143
                                bonsaismith
                                  thanks! i’ll get that one when it’s back in stock then
