:: ciao 93 Malossi Big Deps
Home Forums Perso’s Projecten ciao 93 Malossi Big Deps
15 berichten aan het bekijken - 16 tot 30 (van in totaal 38)
  • #485996
      Very nice ciao, I like the colours : -)
      #486017
      peter139
        nice ride! I like the red color. Very fast setup…. I was wondering what you payed for this stuff in italy?
        #486119
        nejc93
          some new parts =)
          I hope that the good calibreta?!…
          #486120
            Nice exhaust, goes pretty decent on the deps :D!
            I would say: Yellow malossi main spring, white maloss clutch springs & 5 gram rolls
            #486224
            nejc93
              peter139
              thanks
              for parts
              a lot of money
              it depends on which part you ask
              wow looks good
              video how the engine works the first time with calibreto
              #459443
                Nice that you still have the pedals on, cheap kickstart!
                Engine sounds good.
                #459441
                JayL
                  You should let it scream!! 😀
                  #485808
                  luukciao
                    Very nice Ciao!:thumb
                    Sounds good.
                    #486276
                    tvmierlo
                      The ciao looks great, I like the colours with the striping =).
                      #487125
                      nejc93
                        I have a problem with calibreta is not the ciao model :boos
                        I do not understand why? writes that the ciao model!
                        everything goes to my nerves I have not given plastic on the engine :con
                        #487151
                        JayL
                          i believe it is a ciao model, cause the bracket is welded on the right spot. only thing is your pedals can no longer be used.
                          #487159
                            The thing is that the covers (kappen) don’t fit, which is strange especially since the mounting plate/bracket is in place.
                            #487160
                            -RobinvS-
                              Your Engine is full to the front, that might cause the problems, if you find an other fitting fan belt(v-snaar?) u can get your engine more behind and the Calibrata ( Marmitta ) will move backwards too.
                              Think your covers will fit after that.
                              #487178
                              nejc93
                                I moved the engine back a little
                                only hansieb is very different
                                However, the engine moves forward:?
                                me
                                -RobinvS-
                                  Looks like they are the same mate, but hansieb has it’s engine more backwards ( if im right )
