:: Chemical metal
Home Forums English General questions Chemical metal
  • #144284
    ludde863
      Hello
      Im pretty sure I have a crack in my intake, because my ciao suddenly have a very high idle. I also checked it with starting gas(not sure if it is called starting gas in english) and it seems to be the intake.
      Anyways, is it a good ide to fix it with Chemical metal?
      #145659
      SuperSi
        can you post a picture of crack?
        clears things up a bit
        #145976
        pepko
          It depends on wich side of the inlet you are putting it.
          Putting it on the inside doesn’t seem to be a very good idea,
          because inventually it will get loose and end up in your cilinder.
          A picture may indeed help a lot.
          Also I would like to know if your nylon bush (or something like that) is in a good state.
          If the inlet is cracked really bad, the easyest solution is to buy a new carter.
          Gr. Pepko
          #145979
          ludde863
            Well, I guess the problem with the high idle was not the intake, because it looks fine. Pic on the intake:
            http://img42.imageshack.us/img42/8510/dsc06435f.jpg
            So now I have i new question, what could be the problem with the high idle? All the gaskets looked fine to, but of course im going to change them all. But its wierd, when I sprayed with starting gas on the intake the idle bacame lower..
            Hope u all understand my problem.
            #145981
            pepko
              what is the state of your nylon bush that is on your inlet/carb?
              because if it’s in a bad condition it’s leaking.
              also, it could be a problem when your carb. is not pushed on the inlet far enough.
              i guess you probably have to check the area around your inlet and carb.
              gr. Pepko
