:: Can i tell if my motor has a 10 or 12mm pin without opening?
Home Forums English Pub talk Can i tell if my motor has a 10 or 12mm pin without opening?
  • #147430
    eran_k
      Hi guys,
      as the title says, is there a way to know the size of the piston pin (10 or 12) without removing the cylinder?
      my moped is a 1996 Si “monte Carlo”
      Thanks
      Eran
      #147866
      virgil
        only if you remove the cilinder you can see it well.
        #147867
        vicious
          Normally only older vespas have pin 12. But to make sure, removal of the cylinder will be necesserary.
          #147868
          Mike
            I’m pretty sure your Si have a Pin 10 crankshaft.
            only much older models have pin 12
            Mike
