:: Broken plastic cam on points breaker?
Home Forums Techniek Opvoeren Broken plastic cam on points breaker?
  • #185232
    Dea_944t
      Newly built engine (carter and crank re-used) and the plastic cam on the points breaker (contact set) from EFFE broke.
      Bad luck or could there some other issue that makes this happening?
      /Dea
      #202765
        thats normal, the quality isnt that great.
        they wil break above 7000 rpm 😀
        but you try to grind down the cam a bit so there are less stresses on there
