:: Broken piston pin circlip?
Home Forums English General questions Broken piston pin circlip?
  • #144441
    Dea_944t
      The engine started running a bit poor so I removed the cylinder….
      The circlip broke, is this a common problem? never happend on my Ciao engines before
      Is this type of circlip better http://www.jmpbparts.com/vespa-ciao-si/engine-parts/pistons/pistonpenclip-10mm-per-stuk.html
      /Dea
      #146779
        It is not a common problem.
        But where is the rest of the circlip?
        The “running a bit poor” can be the result of a damaged inlet.
        at by the look of it your gasget has been leaking.
        And yes it is a good clip.
        #146777
        Dea_944t
          Hard to say, but it dropped out when I removed the cylinder.
          The inlet and the crank are both ok.
          The “scratch” is 1 mm deep so I had exhaust gas recirculation which explains the poor running
          #146778
          Dr Gonzo
            Last week I’ve had the same problem with the 43mm Olympia kit, same as topic starter; it starts, but no power…
            After I found out that it must be a broken or lose circlip I drove home while cursing and full of anger..Lol
            Them I burned my hand, because I did’t had the patience to wait to get that rotten cylinder off the bike…I was planning an overhaul anyway, but a shame that I killed the 43mm
            Hey Steve, English 😉
            Hey Mod..Zo goed?
            #146780
            niek1992
              A lot of users here on the forum don’t use those clips you used.
              They had the same thing happen as you. Currently on mobile so i can’t give you a few links to other topics where the same thing is displayed.
              Basically you should avoid those you used. They lose their stiffness quite fast, and work theirselfs out of the piston and into your cylinder.
              #146785
              Dea_944t
                Thanks, ordered the other type of clips for my Speedengine build.
                /Dea
