:: Broken Crankcase
Home Forums Techniek Motorisch Broken Crankcase
13 berichten aan het bekijken - 16 tot 28 (van in totaal 28)
  • #824854
    Bravo_999
      Nice thanks!
      It’s my first time ever porting so I was very careful but I think it turned out pretty well.
      If I have any other questions about my project I will share them here.
      #824859
      Bravo_999
        Hey guys,
        I just saw that I have a few scratches in my inlet window as you can see on the last picture. One is along the bottom and one one the right site. Do you think it will still work or not?
        Please a quick answer thank you?17155086648461598504696625615580
        #824860
        Bravo_999
          I would be happy about a quick answer!
          #824862
          Bravo_999
            Could someone just say if it will run properly with these scratches otherwise I will send it back.
            #824864
            Grijze si
              I would try to get it a bit more smooth so your flow wont be infected or so that your crankshaft wont hit those ridges and small pieces of metal might get in your cillinder . Also the canal itself does not look very great or it might be the lighting but i think it could be alot smoother.
              Hatsa
              #824892
              Bravo_999
                Ok, I will try it out. Do you think it would run properly because I think the flow isn’t that important it would probaly result in 1 kmh less. But I am not sure if it will run at all with these scratches. What do you think?
                #824893
                Ewous
                  I would bin that Carter and try to find a other one. The inlet must be smoothe where it hits the crank. Now it wont close properly.
                  #824894
                  Bravo_999
                    ok, i have currently no other choice than trying it. I have poured some oil in the inlet with the crankcase in it and watched if it will come out. After a bit of waiting it came out through the inlet window but it was veeery slow so it’s just a bit leaking. What do you think could it work?
                    Because it’s closing like 95% so I think it could.
                    #824904
                    Bravo_999
                      #824905
                      bram0vitz
                        the replica’s dont seal well on the crankshaft and the bearing surfaces aren’t machined properly, sadly enough.
                        You can try it but don’t expect a good or even well running engine without a lot of work
                        beetje prutsen hier en daar
                        #824907
                        Bravo_999
                          Okay, thank you!
                          I am currently searching for a new engine case but it is harder than I thought! Does somebody know where I could get a new one or is here someone who could sell one?
                          #824915
                          Mischa
                            I would search for an used original. You can get them very cheap. I doubt that you live in the Netherlands, but on this site : http://www.marktplaats.nl there are plenty of parts for the Vespa. Complete engines or engine case also. You can place an advertisment on this site also.
                            #824982
                            mean-machine
                              The dust-bin is the best solution!
                              When I look to the pictures of the surface of the inlet-area I fear for crying.
                              In no-way the shown inlet is comparable with my inlet-channel.
                              It MUST be smooth and blurr-free for best result.
                              btw: Inlet to be treated with extreme care. Take your time!
                              Better half an hour extra work then 1 big blurr.
