:: Broken Crankcase
Home Forums Techniek Motorisch Broken Crankcase
15 berichten aan het bekijken - 1 tot 15 (van in totaal 28)
  • #824596
    Bravo_999
      Hello,
      I have a important question so I would be grateful if I could get a quick response, I have got a new engine for my dr setup and as I was taking it apart I discovered that the crankcase is pretty beaten up, can someone tell me if it is still able to run properly.
      17138825146559159789811818576718171388255696865635414348470611351713882608023341567470222459742
      #824597
        Doubtfull this will work. Is there any light coming through when both sides are placed onto each other?
        #824599
        Bravo_999
          No there is no light but I just have a bad feeling about it so I will send it back.
          #824601
            The broken pieces are no problem at all, but that thin piece here is a bit thin.
            Screenshot 2024-04-23 at 22-30-08 Broken Crankcase – Vespa-Ciao.nl
            But it doesn’t have to be a problem.
            #824661
            Bravo_999
              Thank you for the quick answers!
              So my plan is to get a new engine with a 43mm polini kit. Has someone experiences with this kit and could tell me what the top speed would be when I port everything correctly. And how much of a difference is between the polini and the dr evo kit?
              I would be happy about a quick answer!
              #824662
              Wim
                Here can you find differs between tuning parts etc etc
                Het tunen en opvoeren van je Vespa Ciao of Gilera citta
                #824668
                Bravo_999
                  Hello,
                  I have a quick question, does someone know how good the olympia 43mm kit is and which top speed I would get with my current setup and the kit?
                  I would be happy about a quick answer.
                  #824842
                  Bravo_999
                    Hello guys,
                    So i bought a new crankcase for my 43mm setup and as i opened it, I saw that the inlet window is already ported. Now I am not sure if it is good or not. Could someone give me a quick response if the crankcase is good for my setup or if it is too thin on the sites.
                    I would be happy about a quick answer!171543249616384319584557229237501715432535627206538920128934353
                    #824843
                    Bravo_999
                      I want to work on the crankcase so I would be grateful about a quick response, just if it is ok or not.
                      Thanks!
                      #824844
                      bram0vitz
                        The top wall on the first photo does look quite thin, but it could work.
                        The porting could have been done nicer tho
                        beetje prutsen hier en daar
                        #824846
                        Bravo_999
                          Ok, thanks do you know how I could fix the porting and how I can check if it is to thin?
                          How much is the difference between that porting and a better porting, is it noticable?
                          #824848
                          Bravo_999
                            I have now fixed it a bit do you think it is okay now?17154367295697997707365001375398
                            #824849
                            Bravo_999
                              Should I go more to the left?
                              #824851
                              Bravo_999
                                Hello,
                                I have fixed the inlet window a bit more and enlarged the inlet to 12,5mm. Can someone give me a feedback if it is good like this or if I should fix it a bit more.
                                Should I go more to the left with the inlet window or is it to big then?
                                I need just a quick answer!1715440733871527546338217116899817154407577649034123746076451485
                                #824852
                                bram0vitz
                                  Looks better than before, should be pretty usable for a nice engine.
                                  You could go bigger with the porting, but it would result in a lower crankcase pressure.
                                  For a 43mm cylinder this should do just fine.
