:: Bravo standard exhaust
Home Forums English General questions Bravo standard exhaust
  • #144492
    12V
      What exhaust fits directly on the Bravo model, without removing the centrestand and pedals?
      I’ve tried an original Ciao exhaust, and the replica with loose endcap. The exhaust pipe pushes against the centrestand shaft, before i can get the bracket in the right place behind the frame.
      Does a Tecno, Sito or Giannelli fit?
      I learned that the Citta subframe is very similar to the Bravo, can i use a Citta exhaust? Maybe this one?
      https://www.jmpbonderdelen.nl/uitlaat-dik-model-citta-22mm.html
      If i google translate the reviews, i think it sounds to have similar problems, but the translation is very bad.
      regards, Carsten
      #146811
        You can use a Citta exhaust, but not the one in the link as it is a shit exhaust in my opinion.
        It is noisy, it leaks and it will rust as soon as it comes within a range of 10 km near water.
        Find yourself a Sito exhaust for Citta and you will be allright.
        #146812
        12V
          Thanks for the tip! I looked on Sitos page yesterday, but could only find new Ciao and Si exhausts.
          A bit of research and i found the Sito 0252 model, for the faster Bravo models. Like this one:
          http://www.ebay.de/itm/Piaggio-Bravo-Superbravo-Auspuff-Sito-Plus-SGI-252-e2-8069-Mofa-Moped-NOS-Neu-/272379711653?hash=item3f6b1890a5:g:XhQAAOSwLnBX3QP5
          I found one for ~40€ and ordered it.
          It looks nice, and seems to have a dent for the centrestand and is spaced correctly to fit the Bravo.
          regards, Carsten
          #146814
            I had this exhaust on my Bravo and it was fine. Its not the best performaning pipe when you are talking about high-end setups, but still better than the Tecno version and you can keep your stand and pedals i guess.
            40 euro is the normal price for it.
            #146815
              It won’t fit directly!
              Because of the part of the subframe with the rubber for the centerstand.
              #146816
              12V
                Wilk, it’s just for everyday use with original “brom” parts. I have a second subframe that i’m going to use with a faster engine, no pedals and centrestand, but that’s a different story 🙂
                Jelle, my subframe looks different from yours, both my rubbers are on the inside.
                UPDATE:
                Got it today, very nice quality and perfect fit. Very much bottom end, impressive!
                regards, Carsten
