:: Best cylinder for original Belgian carter
Home Forums English General questions Best cylinder for original Belgian carter
  • #144474
    Dea_944t
      I recently built an engine with a Belgian carter and an Olympia 43 mm cylinder.
      Unfortunately the cylinder broke after ~200 km so I need to replace it with something else.
      Are there any other 43 mm cylinders than Olympia that works well without increasing the boost ports or should I dismantle the engine again and start milling… ?
      /Dea
      #146786
      ! Joor !
        43mm dr evo
        #146788
        SuperSi
          43mm Polini
          #146192
          Dea_944t
            Which has best low-end torque?
