:: Best Crankshaft (Kurbelwelle) for 46mm Pinasco
Home Forums English General questions Best Crankshaft (Kurbelwelle) for 46mm Pinasco
  • #144472
    zultan32
      Hi there,
      I recently bought a 46mm Pinasco for my Ciao Porter.
      Since I don’t have the machines to enlarge the engine body, I want to buy a Polini Speed Engine.
      Which is the best crankshaft for 46mm Pinasco with Speed Engine ?
      Greetings
      Till
      #146773
        Hi I think that a standaard crankschaft will do fine in a speed engine.
        a sandaard crankschaft is srtong and on a porter you want pullingpower. wiht race crankschafts you get power at high rpm,s
        There are people on this forum who have a “mallossiefrees”and can enlage a standaard engine body for you.
        I know leannart has one.
        http://www.vespa-ciao.nl/forums.php?m=posts&q=35289
        And I have one.
        http://www.vespa-ciao.nl/forums.php?m=topics&s=41
        #146775
        zultan32
          Should I mount a new piston rod to my crankshaft ?
          Isn’t it bad to use a crankshaft from an old engine ?
          #146776
            If the thread, the bearing seats, and the flat patch is still good then it’s no problem.
            I would assemble a new piston pin and needle bearing.
            If it is not included whit the PINASCO cylinder; Order one for a 46mm piston.
            A standard piston pin is too short.
            #146782
            zultan32
              Which crankshaft should I buy if the original is broken ?
              I need a good crankshaft for PINSACO 46mm and a original engine body.
              Greetings Till
              #146783
                I’ll still go for a second hand used Piaggio crank. These have the best quality. Furthermore there are some differences with timimgs on other brands/racecranks, but you can always tune your timings. My opinion is, even a standard bromcrank will do fine in a SE or worked Piaggio carters.
                The only good quality aftermarket cranks are from Malossi, but these are hard to find and have a rather big inlet timimg.
                You can start an advertisement here on the forum; http://vespa-ciao.nl/forums.php?m=newtopic&s=25
                #146784
                zultan32
                  Since I’m more into Zündapp mopeds I have one question.
                  When you restore an old Zündapp engine, you would never use a used crankshaft.
                  You either buy a new one, or you find someone that mounts a new piston rod with new bearings.
                  Why is it okay to use an old crankshaft at Ciao engines ?
                  Isn’t it dangerous for the engine, because the material is very old ?
                  Or is the original crankshaft oversized, so that it will last the next 100 years ?
                  Greetings
                  Till
