:: Best 46×10 cylinder for Polini/Malossi block
Home Forums English General questions Best 46×10 cylinder for Polini/Malossi block
15 berichten aan het bekijken - 1 tot 15 (van in totaal 23)
  • #144442
    Italjohn
      Hi guys.
      I’m new in this game.
      Can you give me any good advice on which cylinder has the best lowend power for a Malossi
      I have been looking at Athena with a tripple exhaust port:
      And this from malossi with only one exhaust port:
      #146654
        Definitly go for the polini 46mm! Loads of torque and a decent top speed.
        #146655
          The polini 46 is lower end power compared to the athena/malossi however it is adjustable through exhaust port tuning.
          Be carefull using the malossi cases the new production line has a lot of flaws unfortunatly.. You (in my eyes) are better of get a polini EVO kit wich has a higher quality grade compared to the malossi.
          #146656
            i depends if you use a milling machine, and are good at it 😀
            and you need the 19.5 phbg kit for it, its not going to do anything with a 13 13 carburator.
            the problem with te reedvalve is that the canals are simelar to a stock engine,
            so it recuires a lot of millin and tuning to get right for a malossi or athena
            this is stock porting in a reedvalve
            this was during the tuning period, more than 2 mm of material has to go
            this is the end result for a brevattato 46.5
            good power at the lower rpm, and a top speed of around 80/85 km.h
            so we think youre better of with a polini engine, this has already good ports and it runs sick with a 46 polini cilinder
            #146657
            Italjohn
              Excellent.
              Is it this one?
              Polini 80ccm
              #146658
                No it is this type:
                http://www.spi-parts.com/scooter-parts-performance/piaggio/piaggio-mopeds/ciao/engine-crankcase-ciao-d-19.html
                The one you are linking is for a maximum of 13mm carb’s and is more like a stock case with ports and large inlet ;)!
                #146660
                Italjohn
                  Thanks 😀
                  Is this the cylinder you recomended?
                  http://www.jmpbparts.com/vespa-ciao-si/engine-parts/cylindres/polini-cilinderkit-46mm-ciao.html
                  I’m only after good low end acceleration, not top speed.
                  I intend to use the Bravo in the city anyway 🙂
                  Do I still need this engine, or should I settle with the more tame Polini?
                  Do I have to change the crank as well, or is the stock one ok?
                  And what exhaust do you recomend? (It must fit with the centre stand on)
                  #146538
                    what kind of transmission you got?
                    normally this engine runs over 75 km/h, if you going to use a stock exhaust its a waste of money i think
                    better spends some euros on a variomatic, (1/13 gearing) with a 70cc DRevo and a good city power.
                    that wil do some wheelies like you never seen before 😀
                    the polini evo engine is a fast one, to make it run not faster than 55km/h wil be difficult 😀
                    if the power goes up, the speed wil also go up, unless you wanne ride 50km.h with 9000 rpm 😀
                    #146537
                    Italjohn
                      Hi Ritze.
                      I have a Bravo with all stock, except from a Malossi variator.
                      Look here: [url]http://www.vespa-ciao.nl/forums.php?m=posts&q=36188[/url]
                      Please give me some suggestion to good strong setup 🙂
                      I’m willing to buy all the necessary parts you recomend.
                      1.motor carter
                      2.Cylinder
                      3.Exhaust
                      4.Carburettor
                      5.More I need???
                      #146662
                        The 46mm polinie has smaller ports.
                        I think you be far better of wiht the 46mm. It has plenty of torque at low rpm.
                        It is not specially build for 46 mm cilinders but take an exhaust like the leovice handmade. It is a long pipe and doesn,t allow to much rpm,s.
                        But what ever you do ritze has right. You’ll fly.
                        But for what you say you want:
                        For much less money;
                        Take: a normal tuned blok, a dr evo 43mm,a 13/13caburator, a standaard vario and a leovice handmade.
                        Topspeed 65km/h and exelent pull up.
                        #146663
                        Italjohn
                          Thanks for your feedback Zevenenergie.
                          Can you post some links to the parts I need?
                          I have never heard of the leovince handmade for a Ciao/Bravo.
                          Is it this one?
                          If so, I can’t use it.
                          The moped MUST have a close to original look, and the main stand need work as it should as well.
                          i was hoping to use the Malossi Too bad, any good?
                          #146664
                            Cilinder: http://www.jmpbonderdelen.nl/vespa-ciao-si/motordelen/cilinders-vespa-ciao/dr-cilinder-43mm-vespa-p10.html This is piston pen 10mm, make sure that this is your size!
                            Caburateur http://www.jmpbonderdelen.nl/vespa-ciao-si/motordelen/carburateurs-vespa-ciao/carb-dellorto-ciao-13mm.html
                            I dont know for shure wat type exhaust fits on a bravo with a main stand.
                            The HM is scarce,they are not sold new any more.I think this will do:
                            http://www.jmpbonderdelen.nl/vespa-ciao-si/motordelen/vespa-ciao-uitlaten/proma-circuit-citta-ciao.html
                            Or for a standaard look; take a citty power. I do not know which one wil fit a bravo.
                            I see you already have a vario:thumb
                            #146666
                              If you want torque really use the 46mm bore. First try without variomatic and get the proma cc!
                              Did a test ride on ciao with 46mm polini and speedengine combination and this was more then good 😉
                              #146667
                                If i were you I would go for:
                                Polini Speedengine
                                Polini 46mm
                                Original crankshaft
                                13/13 carburator
                                leovinci SP(silence power) exhaust (if you can find it, in Holland you wouldn’t find it new)
                                #146668
                                Italjohn
