:: a couple of questions..
Home Forums English General questions a couple of questions..
  • #144242
    frutte
      Couldent find a mark on my polini 46mm piston have i mounted it right?
      Could someone mesure the spacer that comes with the malossi vario kit. how many millimeters is it?
      Many thanks!
      Regards Fredrik
      #145668
      olliegasselt
        Fredrik ,
        normally you will find a arrow shaped mark on top of your piston !
        This arrow has to point to your exhaust .
        But in this case your piston is mounted correctly .
        With your other question about the spacer i can’t help you .
        #145669
          Inside ø 12mm
          Outer ø 25mm
          Thickness 10mm
          #145670
          frutte
            Great!
            thank you both! 🙂
