:: 9500 rpm on an OLD 90mm clutchbell?!
KUDOS TO ALL YOU WONDERFULL VESPAPEOPLE!!!
My polini 43 mm W should max at 9500, but will an OLD 90mm bell take that kind of “abuse”!?
MikeBijdrager
hahaha welcome here
but i don’t think a 43mm polini runs 9500 rpm haha:P
and dont worrie, a variator can take a few rpm’s
and what country you from?
Don’t foreget that the clutch is not turning at the same speed as your crankshaft Mike !
The speed of your rear wheel is directly connected to the clutch, with a normal gearing it will turn at 8600rpm @ 75km/hour. Normally a clutch can withstand this abuse upto around 80km/hour (normally people don’t go faster than that with standard gearing)
So don’t worry, but also don’t rev the engine when your backwheel is in the air:P
Sweeeet, many thanks!
It is the “crazy” kit,but 9500 is of course just the polini specs… (My personal favorit)
Ill post it when the KOSO 12V peaks…;)
